Anyone consider using run flats to save weight?
Minnetonka
MN
Most luxury cars these days use run flats to avoid putting a spare tire out back, anyone consider this when shopping for new tires?
Westerville
Whoa whoa whoa, back up a bit.
In case you didn't know, a run-flat tire weighs substantially more than a regular tire. The weight of a spare tire assembly is, at least, a static and sprung weight. Four run-flat tires will introduce a very substantial increase in rotational moment of inertia and unsprung weight. A big no-no in performance and ride quality. The massive Brembo calipers and large rotors coupled with steel suspension arms and cast iron spindles/hub carriers are nightmare enough as far as unsprung weight goes. There is no need to add extra unsprung weight and extra rotational moment of inertia.
E
Minnetonka
MN
I wasn't aware that run-flats weigh substantially more.
Mundelein
I think having a spare is a huge bonus. My current car comes from the factory with run flats. The difference in ride quality between a regular tire and run flat is night and day. When I go on road trips I roll the dice that I don't get a flat, because I run regular tires and no spare.
Sent from my SM-N950U using Tapatalk
Indianapolis
exactly this. I would avoid run flats at all costs
The heavier your wheels and tires, the worse your car performs.
