Genesis G70 Aftermarket Wheel Options
A
Admin1
Guest
Genesis G70 18" Wheel & Tire Size
  • 8.0x18
  • 8.0x18
  • P225/45/R18
  • P225/45/R18
Genesis G70 19" Wheel & Tire Size
  • 8.0x19
  • 8.5x19
  • P225/40/R19
  • P255/35/R19
Genesis G70 20" Wheel & Tire Size
  • 8.5x20
  • 10x20
  • P225/35/R20
  • P255/30/R20
Genesis G70 OEM TPMS Part#
52933 J5000
20" Ace Alloy AFF002 Wheels
20x9 - 20x10
20" Ruff R2 Wheels
20x8.5 - 20x10
20" TSW Sprint Gloss Gunmetal Wheels
20x8.5 40mm 245/35ZR20 - 20x10 40mm 275/30ZR20
20" KeenDesign KD07 Wheels
20x8.5 +40 - 20x10 +55
19" BBS Ci-R Wheels
19" FERRADA F8 - FR6
20" Gianelle Wheels / GFG Wheels
20" Giovanna Wheels / GFG Wheels
20" MOMO Revenge Wheels
20" Vossen VWS-3 Wheels
20x8.5J +26 - 20x10J +35
20" Zeast ST1 Wheels
20" Vertini RF1.1 Wheels
20x8.5 - 20x10
19" ARK-270 Wheels
20" Giacuzzo Design Wheels
20" mbDESIGN KV1 Wheels
20" Niche Misano Wheels
19" Fittipaldi FSF03 Wheels
20" Marquee 3258 Wheels
20×9" & 20×10.5" with 245/35/R20 & 275/30R20
20" Vossen HC-2 Wheels
20×9" & 20×10.5"
19" 305Forged Flow Tech FT101 Wheels
20" Giovanna Bogota Gloss Black Wheels
20" Ace Alloy Aspire Wheels
20" Niche M116 Misano Wheels
20x9" & 20x10"
19" Enkei TY5
19x8.5 +35 on a 255/35 tire
kablammo
1997 BMW 328i Sedan
https://www.apexraceparts.com/wheels/all-wheels.html?apex_wheel_bolt_pattern=33
If you want a good performance wheel (Lighter and not just for looks) I'd give these a consideration. Would require hub-centric rings and I would call to verify fitment.
WEIGHT 21.35 lbs would save nearly 15 pounds per corner and would also help MPG drastically. Performance first, bling second . . .
List of light wheels from TireRack: https://www.tirerack.com/wheels/res...toModel=Stinger+GT&autoYear=2019&autoModClar=
CGO
Bel Air, MD, USA
2019 Genesis G70 3.3T Sport RWD
Here's mine:
20x9 +32, 20x10 +40 Vertini RFS 1.3
245/35/20, 275/30/20 Falken FK510 tires
Eibach Prokit for Stinger GT (.8" drop for RWD cars).
Ride is firmer, but handles better. Wheels are lighter than stock 19" sport wheels. Not my daily driver, so only a hundred miles on this setup but so far, no rubbing.
Purchased the wheels and tires from getyourwheels with preprogrammed TPMS. Had one sensor that had to be reprogrammed, but they sent me a programming tool to use and send back. Works flawlessly now.
