The Kia Stinger GT - Fella Lightweight Brake Rotors Upgrade
These Fella lightweight rotor kits are designed to improve the stopping performance on your Kia Stinger. Upgrading your brake rotors will help provide better heat dissipation, allow for even wear of brake pads, and give you longer life out of your brakes overall. The 2-piece design saves rotational weight giving you better acceleration and even faster stopping. Whether being used for the street or track, upgrading your brake rotors from the standard rotors is a modification you do not want to miss! One of the biggest advantages of 2-piece brake rotors is the rotational weight savings!
Fella brake rotors go through an extensive manufacturing process; heat treated up to 800°C (1472°F), to ensure the rotors can take the punishment from performance driving. Each rotor gets machined, assembled, and balanced by hand to meet high-quality standards.
The Fella rotors feature a round pattern with the options for a drilled or slotted cut. With more effective curved vanes in a V shape, these further help dissipate heat away from the rotors. This design improves cooling by pushing cool air from the center of the wheel to where the rotor needs it most.
Rotors feature a CNC machined aluminum hat that secures the disc to the rotor with hardware that gives a true floating design. The hard anodized brake hat is extremely durable to not wear and scratch like standard anodized or powder coated finishes. Each kit is sold as a complete axle set up (L & R) to work with the factory or aftermarket brake pads and stock caliper.
Features:
2-Piece Rotors assembled with hardware and aluminum hats
Option to choose front (2), rear (2), or complete rotor set (4)
Available in slotted or drilled designs
Full floating assemblies with stainless steel
M8 bolts vs standard
M6 hardware
Anodized rotor hats
Directional vented, heat treated and coated rotors
~Fronts 350x30mm sized rotors, 8.7kg (19.2 lbs) each
~Rears 340x30mm sized rotors, 6.7kg (14.8 lbs) each
Please allow up to 5-7 business days for your order to be shipped out to you.
2018-2019 Kia Stinger (GT Models ONLY)
