Bar & Plate vs. Tube & Fin Intercoolers
Miami
I wrote this awhile back, figured I share it here. Will be updating this thread when more options are available.
Tube and Fin Intercooler
Pros
  • Generally weighs about half as much as a bar and plate core of similar dimensions
  • Generally less expensive
  • Generally less flow restriction within the core than bar and plate designs
  • Allows better flow to the rear of the core and to a radiator
Cons
  • Offers less heat rejection than bar and plate
  • Generally have more fins which means they're more likely to be damaged by rocks/debris which cuts down on cooling efficiency
  • Charge air entry extends beyond core wall making it more difficult for air to enter the core cleanly
Bar and Plate Intercooler
Pros
  • Generally has greater heat rejection than tube and fin design
  • Generally has more varying shapes and sizes
  • Less likely to be damaged by rocks and debris
  • Charge air entry sits flush with core allowing for cleaner entry
Cons
  • Weighs about twice as much as a similarly size tube and fin core
  • More expensive
  • Blocks more airflow to radiators, etc. which may be behind it
  • Those with turbulators have greater flow resistance to charge air
