2019 winter wheels
arnzng
alton
2019 g70 sport
Hello, new to the genesis family. We just got my wife a brand new 2019 genesis g70 prestige sport 2.0t. it has the 19" wheels with the pilot s4 tires. I found a set of genesis wheels from a 2015 18" with 245/45/18 firehawk tires and tpms. From what I've found the wheel lug 5x114.3 hub 67.1 and offset +36mm all seem to fall into what would physically fit on the car for our illinois winters. My question is whether the tpms system is auto learning or if they need to be dealer programmed. It's not a huge deal to have them programmed but to go back and forth between seasons for wheels and tires. I do have a reset initiation tool for 315mhz sensors if that helps. TIA
Welcome to the forums, just take the car to any tire shop like discount tire, they will be able to set the TPM's for you...
Oshawa
2018 Kia Stinger Limited
It's 100% automatic.
No programing required.
Read the attached "description" for the details of how to learn new sensors..
Tldr: - just 2 steps
1. Install wheels with new sensor
2. Drive over 25 kph for ~20 minutes 'ish.
Oshawa
Not required
Gotcha, thanks for the info. I had mine set when I had my wheels & tires replaced.
A
arnzng
alton
2019 g70 sport
Hoping to test this out in a few days. I have an activator tool since they're probably in sleep mode. So I'll wake them
Sent from my Pixel 4 XL using Tapatalk
