LAP3 Pro-Tuner - Dynamic ECU Tuning Solution
Here's a few features of the LAP3 Pro-Tuner that boost chips on the market can NOT do.
- Boost Adjustability: Unlike the boost chips on the market, it doesn't just fool the sensor & voltage to increase boost. LAP3 Pro-Tuner can custom tune the boost pressure per RPM based on the engine load. (See the graph 1)
- Fueling: After carefully analyzing the fuel rail sensor values, rail pressure can be customized and re-mapped per RPM & engine load. (See the graph 2)
- Ignition Timing Tuning - Based on the crank angle sensor values and the boost pressure/rpm, Ignition Timing can be mapped for the most optimal performance setup. (See the graph3)
- Top Speed Governor Removal: Many Stinger owners have been asking us about it, and the LAP3 Pro-Tuner will allow you to unlock the speed limiter.
- PROSS - LAP3 app to give dynamic performance. You will be able to change your maps through the app (Stock, Stage1, Stage 2, Stage3). You can also monitor Live data for your engine condition as well.
- DTC Code Canceler - The owner can select specific DTC codes and remove them automatically.
- Meth Injection System Support (Future Upgrade) - We are working on a meth Injection system to interlock with our phone application. Custom tune ignition timing based on the engine load received from the can, when paired with the Methanol Injection system via PWM controller system.
